Over Constrained in dynamic simulation
lis_wang
lis_wang
I am using a DS in my assembly. However after I added in the constrain, in DS. there is over constrain error. I know the problem is because of mate:10 constrain in Connecting_Rod:1 and mate:9 constrain in Connecting_Rod:2. However these two constrains are must in order to connect both Connecting_Rod:2 and Connecting_Rod:2 to Swivel_Link.
May I know what shall I do? Please see the screenshot. The standard joints cylindrical:4 and cylindrical:6 are redundant
joints.
I attached the assemble file here.
Xun.Zhang
Hi Lisa,
This is an interesting case, tried several ways and the error still appears. will forward to project team to understand it better.
Xun
TheCADWhisperer
See attached.
lis_wang
I noticed that you change YZ plan of the part ISO 2338 8 m6 x 20.ipt from end to the center. But I still use the original content center part.
I amended my constraints at this two joints the same as yours except I match the XY plan of part Connecting_Rod:2.ipt and Connecting_Rod:1.ipt to part ISO 2338 8 m6 x 20.ipt and offset 10mm. The problems still exist.
Another problem is why part ISO 2338 8 m6 x 20:2.ipt is inside the Welded group:1 and ISO 2338 8 m6 x 20:1.ipt is inside the Welded group:2. I used the same constrains to constrain them to Connecting_Rod:1.ipt and Connecting_Rod:2.ipt.
I attached my amended file (with adding more parts) here.
WHolzwarth
Hi Lisa,
I think, it's good, creating sub-assys as much as possible in motion studies. Life will become easier.
New 2018 fileset in attachment.
Smiley Wink But now weather is fine. Time for a break. I'll come back later, if it's still needed.
Walter Holzwarth
WHolzwarth
Now a new fileset. I didn't spend any time with DS, but only animated it in assembly. Move it with constraint Driveme
You can see the problem: The system can only move, if the blue part can slide along it's axis.
This is not good in reality, but I think, some changes in parts geometry would eliminate that need.
Some time later: Have a look at the bearing near the small bevel gear. An additional distance ring is needed for axial fixing. And bearing situation between base and swivel link is rather short
Walter Holzwarth
