origin placement problem
Hello guys,
It does not show the values properly because of the wrong origin placement. How can i change the angle of the origin?
Best regards,
mdavis22569
share the part and IDW...
it'll make it easier
Mike Davis
Thank you in advance
mdavis22569
So here's the issue ...
The origin for your hole table does it vertical and horizontal
you've projected it at an angle in a sense...as you can see in this picture
So if you rotate the view, it would be correct.
This view above rotate is also how it would be set up to be drill most if not  all of the time.
Mike Davis
