Create negative from part
Message 1 of 10
I have seen that this has been asked previously, but none of the replies I have seen have helped me to achieve the goal I am after.
Basically, all that I want to do is create a "plug" from a part file, so I can use this as a fibreglass mold.
For the life of me I cannot find a way to do this, but that is probably because of my limited skills with the more advanced tools, like derive, sculpt and split, which I assume are the things I should be using.
Attached is the part file I am working with. What I need is a plug of the inside of the step well, along with the bits that stick out beyond the floor (upper rectangular surface).
If someone can give me a bit of a step-by-step that would be greatly appreciated, as I am getting really frustrated currently.
Replies (9)
Message 2 of 10
Mark.Lancaster
For furture reference (especially when posting a file)..   ALways indicate the version of Inventor you are using.  ALthough we can determine it after downloading the file (Inventor 2015 file).   It just saves time up front if we knew..  Smiley Happy
@Anonymous  Also welcome to the community..   I would also recommend that at some point you upgrade to Inventor 2015 SP2 and update #3.  You are currently at SP1.
Mark Lancaster
Message 3 of 10
I'll put that on the "to do list", thanks.
Message 4 of 10
JDMather
This angle is not measurable (by inspection) and not manufacturable.
What is the design intent?
Message 5 of 10
That angle dimension is irrelevant. It is what Inventor generated when I used the auto dimension and constrain feature.
I do not understand why when I add all of the dimensions required to manufacture a part, sometimes it does not fully constrain the sketch, but it doesn't.
There is a slight draft from the floor section to the bottom step. From my personal experience in manufacturing fiberglass molds/parts, this is sufficient to allow for the release of the part. I should add that this is not a finished design, mearely an example that shows the "concept".
My main concern at the moment is how I create a new solid that fills the area of the step well. If I can create that then I can move forward.
Attached is an image showing of the area I need to create a negative of.
Message 6 of 10
WHolzwarth
Let's hope, that I understood it well (2015 file)
Walter
Walter Holzwarth
Message 7 of 10
Firstly, thank you very much for the attached file Walter.
I have expanded the model tree to see what you did, but I am having a bit of trouble figuring out how/why you actually did specific things.
To be honest, it seems like a lot of work to achieve what should be a relatively straight forward task. Maybe I am naieve in thinking that, I don't know.
Assuming that I can recreate what you have done (personally, I am a bit sceptical), how would I isolate that surface and make it into a new solid part?
Message 8 of 10
WHolzwarth
Here's another way of doing. Perhaps it's more transparent to you.
There are now 2 solids in this multibody IPT. You can get separate solids with the Make Components command.
Walter Holzwarth
Message 9 of 10
Thanks again.
I will have a look and see if I can work it out.
Will let you know how I go.
Message 10 of 10
The way you did it in the second file was definitely easier to follow. Thank you.
I don't think that I did it exactly the same way as you did, but I was able to achieve the desired result
This is what I did...
Created a mid point plane between the two sides of the step
Created sketch on plane
Projected geometry of steps
Finish sketch
Extrude to next as a new solid
Mirror solid
Turns out that it was not that hard to do, when you know what to do. 🙂
Your help is greatly appreciated.
