Origin ordinate dimension
Message 1 of 9
Y need to set my origin on a circular plate on the tangents intersection on down left corner. How do I do that, inventor doesnt give me the option, it obligates me to chosse an edge.
Here is what i need.
Replies (8)
Message 2 of 9
Mark.Lancaster
Create a sketch that is associated to the your drawing view.   Then sketch lines to create that intersection.   Exit the sketch and start your dimension, placing the orign at that sketched intersection.   Then when your done, edit the sketch and change the lines to sketch only geometry.
Mark Lancaster
Message 3 of 9
mdavis22569
Or ...just place the origin ...
click on it click edit ...
move it in the x 1/2 the diameter of the circle ...  then you don't need to create a sketch
Mike Davis
Message 4 of 9
mdavis22569
https://screencast.autodesk.com/main/details/90ff8135-e0f6-44fb-96eb-5780196a2d5d
Mike Davis
Message 5 of 9
Mark.Lancaster
Go with mdavis22569 workflow..  It's much simplier...  Smiley Wink
I haven't used ordinate dimensioning in a while and I forgot about the edit orgin functions...
Mark Lancaster
Message 6 of 9
Mark.Lancaster
Mark Lancaster
Message 7 of 9
I tried to sketch on dwg, but I cant link the view so that I can draw with snaps referenced to view. I click on sketch and i can draw lines but there are floting on drawing space, without meaning.
Is there something like project geometry on ipt but in dwg, or how do I sketch using my views as references?
Im on sketch environment inside drawin, y try to draw but anchor point doesnt get green to associate new sketch with my view.
Message 8 of 9
awesome thanks, also worked with double click on origin.
Message 9 of 9
thanks  mdavis225569 that was the answer. Also worked with double click on origin
