Applies in inventor 2017:
After section view is active, the performance is unacceptable low!
Please bring out a fix for this issue.
can you post a screencast of the issue?
I can send you my screencasts by email. Do you have your email adress?
Strange thing is that when I save the assemby with section view active, and then re-open inventor and this assy, the performance is good.
ok ... question?
defer update on? ?
I'm thinking it's a setting ..
Also check to see if you have Express mode for loading on too
ok ... question?
defer update on? ?
None of that. I checked all settings. 2016 version behaves good, but 2017 is serious problem.
I'm having the same issue on 2017 build 233 2017.3. I'm trying to edit a pattern to include more components and my performance goes out the window as soon as I highlight the pattern to edit it. I get like 1 frame every 3 seconds. It makes it IMPOSSIBLE to work with. this is unacceptable.
