Inventor Forum
optimized selection is out of bounds
2 REPLIES 2
3D4Play
149 Views, 2 Replies
I've noticed with the latest Inventor 2025.1 and the latest 2025.1.1 releases that the constraint optimized selection ("select other" head's up display) frequently activates in parts of the screen too far from the cursor to be able to use. I'm not joking when I say that trying to use it in this manner is exactly like playing "whack-a-mole". So far, the only fix has been to quit the constraint, then pan or zoom, and roll the dice on the next attempt. Anyone else seeing this, and if so any suggestions on how to fix it?
2 REPLIES 2
James_Willo
in reply to: 3D4Play
Hi, I have no issues with this.
Have you got the latest graphics driver updates? Also, are you using two monitors? (I have one so I can't test if this makes a difference)
James W
Inventor UX Designer
johnsonshiue
Hi! Could it be dual monitors related? Please make sure the monitor hosting Inventor is the primary display.
Many thanks!
Software Test Engineer
