Opening Template Freezes Inventor-can't read bitmap logo
MikeKovacik4928
Advisor Advisor
Message 1 of 8
MikeKovacik4928
When I use the "new" command
I can't use the .idw template to create a new .idw file.
This only happens with the template which has .bmp logos in.
It just freezes Inventor & I have to do a Ctrl Alt Delete, & terminate.
Therefore at the moment I am opening the file as a normal .idw file
and then saving as, this works. Not the proper way, but a work around
See attached PDF giving full explanation with screenshots.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (7)
Message 2 of 8
johnsonshiue
Hi! It looks like the default image editing program on your system is not Microsoft Paint. Try this. Close Inventor and go to File Explorer -> find the image file -> right-click -> Choose Default Program -> select Microsoft Paint. Then start Inventor and start a new idw file. Does it work now?
Many thanks!
Software Test Engineer
Message 3 of 8
MikeKovacik4928
Johnson
It won't allow me to do that.
I get the following message, see attached
Mike
Message 4 of 8
MikeKovacik4928
No problem on my home laptop with the same template.
It opens, however it opens without even loading any of the logos at all.
Weird!
I will try here on my home desktop and see what happens
Mike
Message 5 of 8
MikeKovacik4928
Hi Inventor Users and Autodesk People
This problem was never solved. I am still to this day not using the templates to open, but opening it as an idw then doing a save as.
I would like to try again to undestand and solve this problem. It is obviously linked to some problem with the location or format of
the logo image file.
When I try to open the template Inventor freezes, I have to do an abnormal termination, then I see the message below.
I am not understanding why this started happening about a month ago, but was never a problem before. Nothing has
changed on my software and hardware setups.
Inventor Queries_091_Opening Template Freezes Inventor-can't read bitmap logo-009.jpg
Michael Kovacik
--Cad (28 yrs)
---Cadkey (4 yrs)
---Inventor (4 yrs)
Higher Diploma Mech Eng
Ex Member SAIMechE
Technician Member ECSA
Collaborator (Rank 9) on Autocad & Inventor Forum
Certified Autocad 2013 & Inventor 2013 Professional
Authorised Autodesk Trainer
Message 6 of 8
johnsonshiue
Hi Mike,
Did you repeat the process to register MS Paint as a default editor for .gif file?
Many thanks!
Message 7 of 8
kelly.young
Autodesk Support
Autodesk Support
@MikeKovacik4928 can you attach the .gif and your template to investigate? Possibly delete out any sensitive info first and make sure it still fails.
It's not an animated gif like this is it?
I checked and it inserts into the template just fine, but shows up as image, so my idea there is squashed.
Is it on all image files like .jpg, .png or just the gif?
Message 8 of 8
MikeKovacik4928
Hi Kelly
Sorry about the delay
will come back to you on this one soon.
Like the animated gif!!, didn't realise you could do that.
Mike
