Hello!
Im quite new to inventor, im learning it right now.
I have a .stp file that i want to open. When i open it, a windiw pops up with settings.
If i only select the solids option, nothing opens just an empty new ipt.
If i select the surfaces option too, it opens like the image shows below. Only surfaces.
My question is, how can i open it as a body and make changes/transformations on it?
If I try to reapir it, it finds errors, but i cant heal them.
I added the stp file as an attachment.
Thank you for every information and help, i have no idea what to do!
Solved by JDMather. Go to Solution.
Hi
The author of the file created it as a surface model, so... you have a surface model.
This is not an error, but a consequence of the decision of the file author.
Once opened, you can edit it with surface modeling tools.
Kacper Suchomski
Examine the Attached...
Edit: I just noticed 2 anomalies that I did not fix in the Attached example...
If you return to the discussion, I can create video of simple process to Repair the geometry.
Thank you very much!
I would appreciate the video, I want to learn as much as I can!🙂
Before I start recording the video - what version of Inventor are you using? 2023? 2024? 2025?
