Opening new Drawing problem
mojtaba77f
mojtaba77f
I'm using Inventor professional. I wanna Open a new drawing but i receive this error:
"The template file that you are using to create the new document needs to be migrated.
  Please open it and explicitly save it before using it to create any more documents."
By the way, I installed a Junk file cleaner recently. May it be for?
What's solutions?
Sincerely,
Mark.Lancaster
It simply means your Inventor template was created with an earlier version of Inventor.  You need to open the template directly and save it (to migrate it) to the version you have for Inventor.
Mark Lancaster
MechMachineMan
Reading goes a long way.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
mcgyvr
pfft... reading is so 10 years ago..
mojtaba77f
I changed my project to default and my problem solved .
I'm not so dominant. thanks for helping.
