Bottom line - do you need your job and what software does your job use?
I have to admit that if I picked up Solidworks tormorrow I'd be scratching my head and no doubt frustrated about "why doesn't it work like Inventor" but I think I'd spend my time trying to learn it instead of wasting that time bitching on the SW forum about how their software doesn't work how I expect... Who do you think goes further in life, someone able to adapt and overcome or someone who digs in their heels expecting the world to change around them?
The problem is tho... If you were to eventually realize it's only beneficial to be competant in multiple software packages, and know the pros and cons of each, then how much time and help do you expect from people here when you come asking serious questions, given the attitude and behaviour thus far?
As for stability - I honestly rarely have a problem, like once a month, if that. Like the issues with "it's Inventor fault it doesn't work as I'm used to" I can only presume the problem lies between keyboard and monitor and the system has been setup and looked after poorly.
So... I go back to my 1st question... do you need your job and what software do they require you to use? If they use Inventor and you need the job then man up princess! Or is it a case that they were advertising for Inventor users and you claimed you'd used Solidworks "but it's all similar" and now in the deep end and struggling?!? If you are only able to use Solidworks, as it seems to be suggesting by your rants, then cut your losses and get a job with Solidworks...
Something else I'd think about - how long do you think a company will keep a new employee who's busy cursing software and blaming it for a lack of productivity, constantly pointing fingers and claiming something else was better, instead of showing initiative and a desire to further themselves and overcome the obsticles???
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
