one more way for chamfer and fillet
Hi!
I need to get the following result after chamfer and/or fillet.
The author of tutrial for accomplishing this purpose uses revolve feature for the marked frame
I was trying to achieve this result to use chamfer/fillet,
I didn't succeed.
Is there way to achieve the desired result using chamfer/fillet features?
Thank you.
The  file is attached.
Curtis_Waguespack
Hi s.shivaprem,
Here is a a common method for doing this using the Intersect option of the Extrude tool.
I hope this helps.
Curtis
JDMather
@Anonymous wrote:
Is there way to achieve the desired result using chamfer/fillet features?.....
No.
And in the real world on the real part those features would be created as a Revolve on a Lathe.
