Again, thread question
@Anonymous
Hi!
I need your help in order to understand the thread issue
which we started it  here http://forums.autodesk.com/t5/inventor-general-discussion/thread-behavior/m-p/6374571
Is my logic correct
If I use 26M fastener I need 26M hole
Right?
Thank you in advance
mcgyvr
Right?
If you use a M3 fastener you need a M3 tapped hole
If you use a M4 fastener you need a M4 tapped hole
If you use a M5 fastener you need a M5 tapped hole
If you use a M6 fastener you need a M6 tapped hole
If you use a M7 fastener you need a M7 tapped hole
If you use a M8 fastener you need a M8 tapped hole
etc...
Whatever fastener you use then you need the same for the tapped hole..
If you use a M3 screw it wouldn't make any sense to put a M5 threaded hole..
