Omit Value from MultiValue Parameter iLogic
Hello
I have created a MultiValue Parameter with the Sheet names from an embedded spreadsheet. However I can't seem to make it not look at certain sheets.
Is there a way to delete certain values?
I tried skipping an add occurrence (don't add "x" to list) within a for using an if but it doesn't work.
SyntaxEditor Code Snippet
wb = GoExcel.Application.ActiveWorkbook
Dim sheetNames as New ArrayList
For Each ws In wb.Worksheets
    If ws  IsNot  "x" Then 'dont add this
    sheetNames.Add(ws.Name)
Next ws
MultiValue.List("TESTLIST") = sheetNames
SašoPrijatelj
try to replace
with
If ws.name <> "x" Then
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
This did the trick, thanks!
