offset dim in inventor
Rishi-Bhardwaj
Message 1 of 11
Rishi-Bhardwaj
dear inventor users, can we change dim. style to the like shown in above image in inventor. please help me to figure it out.
Replies (10)
Message 2 of 11
EdvinTailwind
Right-click the dim, check the "Hide dimension value" and then enter a blank space in the box (to get rid of the default <TEXT>).
Then in Annotate -> Leader Text. Enter value and position as desired.
Done! 🙂
EDIT: If you don't want the arrowhead just right-click it -> Edit Arrowhead and choose None.
Message 3 of 11
Rishi-Bhardwaj
how can, I link dimension with the actual value.
please let me know in detail.
Message 4 of 11
CCarreiras
Hi!
Select the dimention, click RMB and You just need to use this option:
CCarreiras
Message 5 of 11
EdvinTailwind
When you add the Leader Text you can choose from parameters in the model, like this:
Message 6 of 11
Rishi-Bhardwaj
Thanks a lot sir............
Message 7 of 11
Alexander_Chernikov
It's not a good method to write the dimension by hand!
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 8 of 11
EdvinTailwind
Indeed, it's not! See the second answer I posted, where the value is generated dynamically.
The result is more or less identical to the nifty solution presented by @CCarreiras - but much slower to produce...
Message 9 of 11
rhasell
No it's not the same, please unlearn this method.
Can you imagine having to perform this method for a few hundred dimensions?
Mistakes will be made.
I use a similar method for arc length dimensions, The whole "Hide dimensions" etc, and it is painful. I use ilogic and have many checks in place to combat errors (Which have happened in the past)
Edit: What happens if you update the model and "d11" gets replaced? Also can you imaging browsing through hundreds of dimensions looking for the correct one, you might have perhaps 5 "30mm " dimensions, which one is the correct one?
Reg
2026.1
Message 10 of 11
EdvinTailwind
@rhasell : Very relevant arguments. I'll strike my previous responses.
Message 11 of 11
rhasell
LOL, it's not all that bad. It has its benefits as well.
The process you mentioned works well.  The point I am trying to make, is not use a parameter when a valid dimension will do.
It becomes more stable when you use a "User parameter", you can then copy and paste leaders all over the drawing, and it will pull the relevant user parameter from the attached part, updating seamlessly.
Reg
2026.1
