- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I trying to create a chute with a base that is parallel to the ground. The chute needs to go from one conveyor to another conveyor which is offset and below the first conveyor. I've tried using the loft and sweep command but not getting the results required.
You can see from the screenshot that using the sweep command doesn't result in an outlet that is parallel with the ground or the entire section base isn't parallel with the ground.
I created the 3D sketch using the other sketches as a guide and by eye. If someone could show me a better of modelling this that would be great.
It's like looking at this chute as a slide with 2 opposing directional changes while keeping the base parallel to the ground.
I'm just not sure how to model this to get the required results. I don't mind working with a solid or surface but the chute will made from sheet metal.
