Odd Behavior of Ordinate Dimensions
Attached is a video I have been able to recreate some odd behavior when trying to use ordinate dimensions. After creating a base view and auxiliary projected view I try and dimension geometry from the front edge of this machine. In the base view this seems to be fine with no issue. In the auxiliary projected view after a short distance from the same edge it will not allow me to select geometry aligned to this edge.
I can move the created ordinate dimensions to the points which it will not let me select to add a dimension. The command line appears to be stuck asking to select a centerline even when the feature is a center point, or in other cases not even a cylindrical object.
I have double checked that this geometry is perfectly flush and perpendicular so there should be no issues with alignment to the views.
