Inventor Forum
obtuse bracket help
4 REPLIES 4
Mark.Valenti
283 Views, 4 Replies
obtuse bracket help
Trying to make this using sheet metal tools within inventor.  I can picture this in a flat view it would be a hockey stick/boomerang shape. attached is a roughly constructed model..  How can you add a flange with edges that are "skewed"?
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
4 REPLIES 4
mdavis22569
in reply to: Mark.Valenti
I have a different question ...
Let's say it is able to be done ...
How will you make it?
Mike Davis
JDMather
For a properly constructed part you should be able to delete all of the features (in most cases) without any sketches going "sick" or grounding any user Workplanes.
(see attached)
Oops, I see a I need to make a couple of changes to Sketch2 - but this should help get you where you need to go.
Edit: No wonder I had trouble.  Your Sketch2 was not fully defined!
Mark.Valenti
in reply to: mdavis22569
cut a non symetrical chevron shape and bend it at the inside and outside corner.
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
Mark.Valenti
in reply to: JDMather
Thanks, and yes, it was only intended for a visual.
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
