OBJ to solid, Mesh Enabler
Hi!
I downloaded Mesh Enabler due to the post answer: https://forums.autodesk.com/t5/inventor-forum/obj-file-to-a-solid/td-p/8240032
Now I have restarted Inventor but I still don't have an option "Convert to Base feature". Mesh Enabler download was successful.
Inventor2019
Windows10, 64
MeshEnabler 1.0.9
Sergio.D.Suárez
Hi, You must place the cursor on the mesh body. as I show you in the imgen below.
I hope this helps. Best Regards!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Sergio.D.Suárez
Excuse me forget to mention that First you must activate the add-on as I detail in this image.
Mechanical Designer
I noticed that Mesh Enabler doesn't appear on this list. By checking control panel, I can see that it is on the program list, however. Do you know what I should do? Or should I change the placement of the files of Mesh Enabler? Thanks for the answers.
Sergio.D.Suárez
Hi, look at your image, I've highlighted where mesh enabler is, click on it, and then check the lower tabs to load it into Inventor
Mechanical Designer
Oh, it is there now already in my screenshoot also, sorry I didn't notice! I will test it tomorrow when I get to my job, I guess this could work... I will tell
Thanks, it is working
