Inventor 2020 Leader Multi-line Text/Font Bug
bvankauw
bvankauw
Weird font issue in 2020 while placing leaders.
One thing I found strange is 2020 did not force me to migrate the style library? Could be that I missed a step?
Cadmanto
Can you post pics of what you are seeing?
See if this link helps you migrate the styles library.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/CloudHelp/cloudhelp/2020/ENU/In...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
bvankauw
I thought I tagged the screecast in the initial post, apparently not.
https://autode.sk/2G6Etlf
I have normally followed the process you sent for migrating the style library, but now when i select our 2019 style library, the "Migrate" button does not light up.
johnsonshiue
Hi! 2020 styles library is pretty much the same as 2019. There is no format change so it does not need to be migrated.
The behavior you showed in the video seems that the Leader Text has a font but the Text Editor has a different font. Could you share the idw template here? I would like to understand the behavior better.
Many thanks!
Software Test Engineer
bvankauw
Template Attached
johnsonshiue
Hi! Many thanks for sharing the dwg file! I am able to reproduce the behavior. This is wrong. I check our defect system. It seems to be related to INVGEN-28959. I will work with the project team to understand the issue better.
Thanks again!
