NPT Thread Length does not update with iLogic Feature.ThreadDesignation
jrobinson
jrobinson
I was attempting to write a simple iLogic form to handle a few pipe sizes with NPT threads. I created a Thread Feature ("Thread1") on my pipe, turned off "Full Length" and set Specification Thread Type = NPT and Size = 1.
Under Parameters I have OD and ID for the model and a User Defined multi-value parameter called SIZE with values 1, 1.5, and 2 and added this parameter to my iLogic form. Then I created a Rule with this code:
Select Case SIZE
Case 1
OD = 1.315
ID = 1.049
Case 1.5
OD = 1.900
ID = 1.610
Case 2
OD = 2.375
ID = 2.067
End Select
Feature.ThreadDesignation("Thread1") = FormatAsFraction(SIZE)
The form works as expected and it sets the correct NPT Thread Size, but oddly it does not update the length. Thread lengths should be for Size 1 = 0.985 in, Size 1 1/2 = 1.025 in, Size 2 = 1.058 in. These values appear in the Length field when you change the Size under Edit Feature for Thread, even though it's greyed out when Thread Type is set to NPT.
Using the iLogic form to select Size and have the rule change the thread should update its thread length, but it remains the same unless you go Edit Feature for Thread and change the size there. Only then you can notice the visual change to the model. But how can I trigger this change using iLogic code? I noticed Inventor creates a dimension parameter for the thread length which gets updated when clicking Apply under the Edit Feature for Thread. I guess I could name this parameter TL and set the thread length manually in my code, but I shouldn't have to. Any one have any ideas why this doesn't update accordingly or how to force the change to occur in iLogic?
Curtis_Waguespack
Hi jrobinson,
When you create a Thread feature, there is a model parameter created. You'll need to add that parameter to your Select Case statement.
In this example I've renamed model parameter d14 to ThreadLength. See attached Inventor 2015 file
Select Case SIZE
Case 1
OD = 1.315
ID = 1.049
ThreadLength = 0.985
Case 1.5
OD = 1.900
ID = 1.610
ThreadLength = 1.025
Case 2
OD = 2.375
ID = 2.067
ThreadLength = 1.058
End Select
InventorVb.DocumentUpdate()
I hope this helps.
Curtis
jrobinson
Yeah, I noticed the parameter that was created as noted in my original post and what you suggested is what I ended up doing.
I was just hoping that I wouldn't have to define the thread length individually based on the NPT pipe size chart values I have on a sheet. It seems that Inventor is aware of these values already as it sets them correctly when you actually edit the Thread Feature despite that it has the Length field greyed out when Full Length is not checked and Thread Type = NPT.
I figured when there is no class or designation for the thread, only the size, that setting this in iLogic would also apply the typical length, but sadly it does not. Seems like a bug that's probably been there for a long time. Smiley Embarassed
Thanks though!
