notes & leader editor
Hello
I want to create the default setting for notes & leader.
required data is Qty must be automatically update. And there around some 52. so for every detail i need to give edit Quantity note.
And for some i need to give tap drill size. & some of them i need to provide thread depth. with depth symbol.
So weather there is a simple method to edit all this things in less time.
mcgyvr
I don't think so..
I think you just need to do it and change them all one by one..
SBix26
In theory you can use a good XML editor to edit Dimension.xml directly, and possibly take advantage of copying and pasting.  But there are no labels in the XML file to tell you which hole type corresponds to which settings, so it's probably no benefit.
You can also use the Apply to All button per these instructions from the Help: "Click Apply to All to apply selected settings to all hole and thread types, including settings in the Precision and Tolerance dialog box."  This may be a great help in covering all 52 different hole types with similar settings.
Sam B
Inventor Professional 2018.1.1
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
