Change the normal dimension to diameter dimension.
Hi
Weather there is a option to change the normal dimension and add diameter symbol dimension.
shortcut method to create.
If you double click on the dimension, on the text tab of the edit dimension window, you can add the diameter symbol from the symbols pallet on right hand side of the window.
Anite
@Anonymous Thank you
I knew that answer but for every time i need go to edit add symbol. so i am finding a new method. i used copy properties and use to set.
but i want something new to create.
salariua
Chose your selection carefully and it will add diameter automatically.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
@salariua Ya sir.
Its right other any method method because mostly i use retrieve dimension. And there will be around some 20 dimension i need to edit. so any tricks.
salariua
it works with retrieve dimensions too if you build your model correctly.
extrude a circle or revove with centerline dimension
Adrian S.
blog.ads-sol.com
@salariua
Sir you say that center-line is must to get the diameter symbol.
