Working in a .ipt file, the attached shows a internal splined cog that has a notch on each tooth. I am trying to get the notches to change in count to match the count of teeth and still remain centered on the tooth.
I got the notches to constrain to the minor diameter so when I change the minor diameter to a larger or smaller number and back the notch follows suit.
The issue is when the count of the teeth change the notches do not remain constrained to the center of the tooth. I believe they are clocking from the original position which is based on the the angle of rotation origin.
The drawing is based on space width instead of tooth width therefore I had to start the notches using a formula of half the angle of rotation based on number of teeth, if that makes sense.
