Inventor Forum
Not display thread in model when pattern hole
5 REPLIES 5
tonythm
453 Views, 5 Replies
I don't understand why not show thread in model when i use pattern command. I'm using inventor 2023.3
5 REPLIES 5
JDMather
in reply to: tonythm
@tonythm
Attach your file here.
tonythm
in reply to: JDMather
@JDMather
If using tapped hole to pass through 2 solid body, thread will not be display when pattern command.
But i just found out that, when i use end of part pull up to fix them, there is no problem (002999A)
In the file 002999B, I deleted all feature, and I still got the same problem as before.
I don't understand what's going on with the Inventor 2023.3 i'm using.
JDMather
How will these be assembled without clearance between cylindrical faces?
(Cannot manufacture perfect parts.)
It is unusual to thread counterbored holes - they are usually clearance holes for fasteners going into another part - but I don't know your full Design Intent.
@tonythm
Try setting Adjust in the Circular Pattern.
blandb
In 2024 When I opened your parts I did see the threads missing. I then removed the top solid (solid 5) from the circular pattern and the threads appeared. I then added the top solid back to the pattern and the threads stayed.
Autodesk Certified Professional
tonythm
@JDMather
Thank you so much!
It's a layer of plastic used to insulate.
They are assembled from many pieces. When make 3D, it is a solid for insulating material. On bolt and washer also have insulating material.
Below is the section parts.
