Hey there!
For some reason I'm not able to move the End of Features tab for some reason and it's about a lot of my assembly, I'm able to see the parts and select them but when it comes to adding more constraints and adding material it become very finnicky and isn't consistent on what I can do with it.
If anyone knows the problem and a way to fix it that'd be really appreciated
Thanks for you time!
Solved by gcoombridge. Go to Solution.
Your end of features should only be able to move in the range shown below. It is only there to roll back the sequence of assembly features not the occurrences themselves.
You can't use it to isolate parts if that is what you are looking to do? There are other approaches for that
Hi! Yes, @gcoombridge is right. Inventor assembly is not history based. All components at the same level can be swapped in and out without any order. The only thing historical is assembly sketches, features, and weld beads. These are indeed order based. EOF operates on those, but not on individual components.
Many thanks!
