I'm not able to update with the Autodesk Desktop app. (the app doesn't work on my computer, even after trying all the steps I found on the internet).
Is there another way to download updates? For example Inventor 2021.0.1 Update.
I don't see inventor in my Account neither.
-Bart-
Solved by mdavis22569. Go to Solution.
What type of license do you have ...
Can you share a screenshot of your Account Manager for Inventor?
(WITHOUT SERIAL NUMBERS IF YOU HAVE THAT STILL)
For 2020 you should really only see 2020.3 for available / needed update if you have none
We (@work) have a license with a file (*.lic) on the server. I don't see any software.
I have Inventor pro 2021 and Autocad 2021. I think it's installed with another Autodesk account?
If you have a work / network license ... then likely you're not assigned it.
So your Contract Manager or Software Coordinator would have to assign the software to you / or download it to say a network location for all of the users to install.
And sorry I see you're on 2021 .. so you are correct .. 2021.01 is needed
I would give them ( CM / SM ) to monitor for updates
This way they know what updates are available.
I'd likely expect 2021.1 to be released in the next few months ( going by prior year releases of updates) ...
This is what I see...
I contacted my contract manager and they made me sofware administrator. Now I can see the updates again.
Thank you for the info!
With kind regards
Bart
