non standard thread data
safiredesignengineers
Message 1 of 15
Hi Group
I have a part with 46mm o/d and i want to put a male thread on here with like a metric fine 1, 1.5mm or 2mm pitch but in inventor the threads offered in iso metric are only 45mm or 48mm o/d?  why can't I set the diameter to what i want?  or is there another way of doing this?
I did select "metric forming screw threads"  which looks like it is doing the right thing but i 'm not sure what the sizes are referring to,  with size 1.5 the designation is 1.5 x 0.5  is this a 1.5mm pitch 0.5mm deep??
although when i select this option and apply a box pops up saying "create thread feature: problems encountered while executing this command"  and i'm not sure why
regards Adrian
Replies (14)
Message 2 of 15
jeremy_wasserstrass
I would edit the threads.xls file. That way you can just use the standard threading options for an external thread or a hole. For 2015 it is in the Design Data\XLS\en-US folder.
Using Inventor 2026 on Windows 11
Ideas needing support: spur gear tooth profile, rack gears generator
Message 3 of 15
mdavis22569
Can you post a picture or the file?
However to do it,
 OD you need it to be 45mm ..not 46. It won't let you do it smaller than what the OD is
46 dia ...errors
45 ...no problem
Mike Davis
Message 4 of 15
mdavis22569
they are standard .. here's what is avail for 45mm diameter items
Mike Davis
Message 5 of 15
Hi  Picture enclosed, thre O/D on the part is 46mm it can't be different, I can machine the thread on the lathe as i just select the diameter and pitch i want but i would like to detail it in the drawing.
regards A
Message 6 of 15
mdavis22569
But the finished product is 45mm diameter thread?
If you just need an image to show up? Or for the call out note on the IDW ?
Mike Davis
Message 7 of 15
but i want a 46mm diameter thread?
Message 8 of 15
i know i can cheat on the drawing but i would like inventor to assign the thread i want if possible.
Message 9 of 15
mdavis22569
Well now I see ...I thought you wanted 45,
edit the Thread excel spreadsheet and add it ... just put in the proper requirements.
Mike Davis
Message 10 of 15
I can't find the spreadsheet? I did a search on my C: drive for threads.xls but nothing came back.
i am using inv 2016 so i assume this still has the xls sheet?
Message 11 of 15
SBix26
Public Documents\Autodesk\Inventor NNNN\Design Data\XLS\lang\thread.xls
Sam B
Inventor Professional 2015 SP2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Message 12 of 15
found it!  does anyone know of a web site that has a chart all the thread data for odd threads i.e m46, m47 etc..
A
Message 13 of 15
mdavis22569
http://mdmetric.com/tech/M-thead%20600.htm
Mike Davis
Message 14 of 15
hi Michael
I use this chart but it has gaps between conventional threads i.e the 46, 47 etc.. i was hoping somone had worked out the bits between and posted it as a full chart
Regards A
Message 15 of 15
mdavis22569
Google metric Thread charts, I found about 30 pages right away and just picked on to post..
maybe google M46 x ? thread chart ..
Mike Davis
