Inventor Forum
No nuts in bolted connection with custom bolt
13 REPLIES 13
Message 1 of 14
roelfoubert
955 Views, 13 Replies
I have a problem with a custom bolt in the bolted connection.
I want to add DIN 15237 to the content center. I thought it was succesfully done, but with the bolted connection I can't select a nut.
What is the best procedure to make a custom bolt to work with the bolted connection?
13 REPLIES 13
Message 2 of 14
johnsonshiue
in reply to: roelfoubert
Hi! I guess the standard libraries required in this workflow are not included. Close all files. Go to Get Started -> Projects -> click on Configure CC Library (the button on the right at the bottom) -> make sure DIN standard is included.
Many thanks!
Software Test Engineer
Message 3 of 14
roelfoubert
in reply to: johnsonshiue
The standard libraries are checked in the project file. When I change the custom bolt to a Din931 the nuts are visible. But with my custom bolt they don’t. So I think I missed something when I publish the custom bolt, but I don’t know what.
Message 4 of 14
johnsonshiue
Hi! Please share the custom bolt here so we can take a closer look?
Many thanks!
Message 5 of 14
roelfoubert
I've attached my custom bolt.
Message 6 of 14
jan_priban
 when I open your bolt, it seems bolt has not been authorized. Components/part used in AddIns like Bolted Connection / Frame Generator / Tube & Pipe have to authorized. So you need to authorize our bolt.
Regards
Jan Priban
Message 7 of 14
roelfoubert
in reply to: jan_priban
I did this before publishing the part. But then I can't select a nut in the bolted connection.
Can you test this for me? And tell me what I'm doing wrong?
Message 8 of 14
jan_priban
OK, I can help you, but the part you sent is bolt
but you are talking about nut :). Send the nut please.
Jan Priban
Message 9 of 14
roelfoubert
This bolt is a custom bolt. I want to use this custom bolt in the bolted connection. But then I can't use the standard nuts in the bolted connection like DIN 934 for example. So I thought I did something wrong with the publishing of the bolt.
Message 10 of 14
jan_priban
Sorry, I see what you want.
Your bolt is OK,  but no nut pairs with your bolt, right?
Message 11 of 14
roelfoubert
correct. It needs to work with the standard nuts in the content center.
I tried doing the same steps with a standard bolt and I get the same result so I think I do something wrong with authoring or publishing to the content center.
Message 12 of 14
jan_priban
basically there is nothing wrong with bolt you made, model is nice 🙂
Based on Content Center / Publish recommendation and my suggestions:
- there are some parameters duplicates (like r, R) and Content Center is not case-sensitive, so r=R which is wrong
- can be resolved by rename, but in your case by Purge parameters since not all parameters are used/required
- make your bolt iPart (even it has only one member/row)
- add Thread info into iPart table (Class, Designation)
- re-author (hex Head category is OK even your bolt is not hex head)
- all should be fine like I see on R 2020.3
(Seems like your current bolt version has a thread somehow incompatible with nut thread.)
Regards
Jan Priban
Message 13 of 14
roelfoubert
Thanks it works perfectly with inventor 2020.2.2.
What is the Grip Length from the bolt? It's not clear to me which parameter I need to link.
Message 14 of 14
jan_priban
It should be distance between end of thread and bottom head side. But to be honest, inspecting existing bolts from Content Center, it is something else, e.g. constant value / number (not parameter).
Sorry, no clear answer
Jan Priban
