No materials in materials libraries
iklompe
Message 1 of 8
iklompe
I am missing my materials in my material library, and i do not have an idea how to fix it.
Project file is ok, the only thing i can find is that if you go to material, the library shows an yellow triangle. (and that is probarbly not good)
But if you want to locate the file, inventor says that the file is already in use.
Anybody an idea, what is happening.
Replies (7)
Message 2 of 8
kacper.suchomski
Hi
Are you using a multi-body part?
Kacper Suchomski
Message 3 of 8
johnsonshiue
Hi! The library is probably corrupted. Do you still have access to Inventor Material Library or Autodesk Material Library (go to Project settings -> Material Library)?
Many thanks!
Software Test Engineer
Message 4 of 8
iklompe
Yes, using multibody
Message 5 of 8
iklompe
According to our Autodesk supplier (Cadac), the file is not corrupted, because i send it to them, and they can actually open it.
Message 6 of 8
johnsonshiue
Hi! The ipt file isn't corrupted. What I meant was that the material library was corrupted. Can you share the library .adsklib file here?
Many thanks!
Message 7 of 8
iklompe
You cannot upload that file format, well that is nice, zipped also not possible.
Message 8 of 8
SBix26
.zip file format is accepted as an attachment in the Autodesk forums.  If that doesn't work for you, try simply renaming it to .txt.
Sam B
Inventor Pro 2024 | Windows 10 Home 22H2
