No hatch lines in section view
manneschmiet
Message 1 of 11
manneschmiet
I'm trying to section a drawing, and while creating the section view is easy, there are no hatch lines on the section views.  I've attached the drawing I'm working with.
Replies (10)
Message 2 of 11
CCarreiras
Hi!
Your part is just a composite surface... a shell... doesn't have a solid body, so, you can have a section of "nothing".
To have a section, first You have to turn the surfaces into a solid body.
CCarreiras
Message 3 of 11
manneschmiet
How do I convert it to a solid body?
Message 4 of 11
JDMather
@manneschmiet
Right click and select Repair Bodies...
Select All
Well that didn't work - so we need to dig deeper...
Stitch shows where the issues are...
We enter the Construction Environment and see that there are surfaces that should not exist in the model...
In some cases there are duplicate surfaces overtop of each other...
Message 5 of 11
kacper.suchomski
Use Stitch or Sculpt
Edit:
@JDMather  You're right.
I was reading this post on my phone and didn't check that the geometry is broken.
Thank you for feedback.
Kacper Suchomski
Message 6 of 11
JDMather
@kacper.suchomski
Can you demonstrate how to use Stitch or Sculpt with this geometry?
Message 7 of 11
manneschmiet
Yep, still stuck.  I was sent this drawing as an IGS, but don't know have anything else to use to correct it, no other original info.
Message 8 of 11
TheCADWhisperer
@manneschmiet
Can you Attach the original IGES file here?
Message 9 of 11
manneschmiet
Hmmm, I tried to attach the file, but it said that .igs files are not supported and I couldn't attach it.  What next?
The file type (.igs) is not supported. Valid file types are: 3dp, 3ds, 3mf, ach, ai, art, anc, arp, ass, asx, avi, axm, bm, bmp, brd, cam, cfz, chm, cps, csv, dbf, dcl, doc, docx, dru, dst, dwf, dwfx, dwg, dws, dwt, dxf, dyf, dyn, eco, env, eps, esri, f3d, f3z, fbx, fm, gif, gz, gzip, iam, ics, ide, idw, iks, ipn, ipt, jfif, jpe, jpeg, jpg, lbr, lin, log, lsp, ma, mac, max, mb, mcr, mkv, mov, mp4, mpg, msg, mwv, nc, nc1, nwc, nwd, nwf, obj, obk, pat, pc3, pdf, pkt, png, ppt, pptx, prj, pro, psd, rar, rfa, rft, rlf, rtd, rte, rvt, sat, sch, sdf, sdf, sdf2, sdf3, shp, shx, simstudio, sldasm, slddrw, sldprt, sol, spf, step, stl, stm, step, stp, svf, svg, tap, text, tif, tiff, txt, ulp, vcf, vtf, vtfx, wmv, xls, xlsx, xml, xps, zip, mix.
Message 10 of 11
CCarreiras
After some struggling... here is the solid...
I will not explain how to do it... (to complex)... but I can give you the part, and now you can have the sections,
CCarreiras
Message 11 of 11
manneschmiet
That's incredible because I know it wasn't simple and took far more than I could fathom to solve.  Thank you.
