No Dimensions
![](/skins/images/A77F558DFEABF42D5D30C54F55DB2263/responsive_peak/images/icon_anonymous_message.png)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi,
I've tried finding an answer to this but I've not really found any useable information on how to do it.
When I create a new sketch in Inventor 2014 and draw a line, I get a little box to enter the length of the line I wish to draw, which is fine. However, as soon as I press enter to commit the dimension of the line, I get the annoying green arrow writing the dimension on my sketch. I don't need that, since I entered the value, I know what the value is, I don't need it to be graphically displayed and clutter my sketch with superfluous information. Is it possible to disable this feature. I mean, sure, I can delete the dimension as soon as it displayed but that slows me down. As an alternative solution I could accept a way to hide all dimensions on a sketch by default, without having to select them individually. (I have noticed that when I don't enter a particular dimension upon drawing the line, then no dimension information is being displayed but in doing so, I would later have to use the dimension tool to make sure that my general design has the desired dimensions and that's still double the work-load.)
And anothing thing, whenever I draw a line, the program assumes that I want to draw another line that is connected to the endpoint of the first and in order to prevent that from happening I have to press esc on my keyboard. The program assumes that whenever I want to draw a line, I actually want to draw a polygon. But to me a line is merely a line, part of a polygon or not. Is there a way to prevent this from happening?
Thank you for your help.
