Inventor Forum
No default drawing templates in 2015?
5 REPLIES 5
ben_mahony
689 Views, 5 Replies
ben_mahony
Hi all,
I just updated to 2015 product design site.
All going well with modelling, but when I try to open a new drawing file, I get a message saying templates need migrating? Has a little sub message that says to migrate them just open and resave them.
issue it the exits out of the open drawing dialogue.
I just want the default metric templates. Any idea where they are installed? And how do I 'open' them?
Hi all,
5 REPLIES 5
blair
in reply to: ben_mahony
blair
The default location for Templates is: Users>Public>Public Documents>Autodesk>Inventor 2015. Make sure that Inventor is pointed to this
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
blair
blair
Sounds like you are opening a last versions Template. Since we have our own templates. This is the first thing that we do it open each Template and Migrate to current version and then do the "Save-As Template".
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
bob_holland
bob_holland
Autodesk Support
Autodesk Support
Ben,
I think you browsed for you old IPJ and it is pointing to 2014 locations.
Are others in your location using the same IPJ with a 2014 product?
Bob Holland
Autodesk Product Support
Ben,
Bob Holland
blair
in reply to: bob_holland
blair
Sounds like you exported your old Inventor settings and imported them into the new version. This is why it's pointing to the 2014 template directory. Check your Application>File:
The Default should look like this:
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
ben_mahony
in reply to: blair
ben_mahony
Thanks for all the help, issue ended up being that I had not migrated the project file, so it was still pointing to 2014 templates and so the default were pointing to 2015 templates but the defaults were being overridden by the project file pointing to the wrong place.
Created a new 2015 project and are currently using it with much more success.  Thanks all again.
Ben.
Ben.
