- Mute
- Permalink
- Report
I'm new to Inventor. I going through the weldment or "frame" design process. I created the body to define my LxWxH of my frame. I added a sketch for a gusset. In the assembly I added my structural members to get my frame base. Then a structural member for one gusset on the bottom back left corner of the frame. I mirrored the gusset to the bottom front left, then both of these to the right bottom corners. Then all of these to the top of the frame. Then I change the angle line in the sketch controlling the length of the gusset from 12" to 10" and low and behold, NONE of the mirrored gussets updated. Do I really have to pull a structural member for every gusset? Solid Edge, Creo, Solidworks, everyone else treats these mirrored features as associative to the parent. Am I missing a setting that isn't turned on or something. This will get really annoying really fast if I can have a structural member that will be the same in all locations be linked to the parent.
