New mark feature, layer in dwg / dxf, save copy as from part vs save copy as from dwg
- Mute
- Permalink
- Report
Hi. We've just installed 2023 and I've been looking at the new mark feature. Before this install we were having part numbers and revision numbers etched onto sheet metal parts by our suppliers, so I want to see how to translate our process.
Currently, to give us control of where the etching is and what size, in our .dwg of our part, we create a blank sheet with a flat pattern view. On the view we add Text, where we use the iProperties of the part to fill in the part number and revision number. This ensures we don't see it in the model and places the characters on a Dimension layer, rather than the Visible layer. Our suppliers requested this, so that their software can determine between a cut through and an etch. We then save copy as dxf from the drawing. We actually use an ilogic rule to generate dxf, pdf and STEP file in one go, but that rule is only performing save copy as function and I can replicate my issue without the rule.
With the new feature, Autodesk recommend creating it in the flat pattern of the .ipt, so that it doesn't appear elsewhere, so that works for us no problem.
I've also been through the Styles Editor in the .ipt and changed the text to suit what we want. I've left the layers as 'out-of-the-box' for now.
However, I can't seem to get those layers to translate to the .dwg. If I do a save copy as dxf from the flat pattern in the .ipt, those layers do come through to the dxf no problem. If I save copy as dxf in the usual way from the dwg they don't.
I see the text but it's on the Visible layer, which means I'm likely to get it cut through by our suppliers. Is this a flaw, or am I missing something? In the flat pattern view in the dwg, if I select one of the characters, I can see from the Annotate ribbon that the layer is the Visible one, so it must stem from there. I can't find anything in the Styles Editor for the drawing that might control it.
