Nesting Utility Dxf Export
When I export a dxf in the nesting utility it gives me a dxf on different layers, the nesting, sheet size, renment, parts list etc
Is there a way to just export the nesting as my cam software picks up all the layers and makes them as if they all are to be cut or do I need to open the nesting in cad and delete everything except the actual nesting??
phillip.doup
Hello @Anonymous,
It is not possible to completely disable the additional geometry being exported into the DXF at this point in time, but we do have plans on adding more control on how and what things are exported to DXF. As usual, I can't promise when this will make it into a product release, but I can promise that we are aware of the limitation and we have discussed solutions for this already.
 Phillip Doup
 Architect - Fusion Platform UI
Thanks Phillip, appreciate the reply 🙂
NewEra_Manf
Any updates on this as far as controllable functionality for dxf exports and disabling misc. data and annotations from dxf export.
jyager
Is anything going on with this? I've got 35 120 x 60 sheets I'm going to have to delete over 1500 pieces of geometry from, manually?
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
cadman777
When I was interested in this subject in the past, I read in the AutoCAD forum how they process the files and views using AutoLISP. Maybe if you go to that forum and post your question you'll find some code you can run to lighten your workload?
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
jyager
Actually looking closer at the DXF, it appears all of the non nested entities (sheet outline, dimension text, piece part numbers &file names are all different colors but on their own layer. It's easy enough to turn them off and less time consuming than manually deleting them. Still kind of a strange work flow.
Jason Yager
Windows 10 Pro 21H2
32GB RAM
