Nesting functionality
a881996FPGN
a881996FPGN
Hello, i modeled a single assembly with multiple components. Most of the components are same materials and same thickness so i could optimize those using nesting. Is there an option where i can define the number of assemblies i will produce, so the nesting have in count the most components possible in the stock of the nested sheet? Of course i can copy and past the assembly so i have the total amount i want, but in large scale this would be not practical.
CCarreiras
Hi!
You can set the number of assemblys (an even the number of extra parts) when you are creating the nesting.
CCarreiras
a881996FPGN
Hi, thanks for the response
I have to do that in the Template i will use?
CCarreiras
No.
It's available in all templates.
CCarreiras
CCarreiras
Check it here...
Let's say you need create 10 assemblies:
CCarreiras
