Hi all,
I just nested my first significant job. 51 unique parts of varying quantity across 12 sheets of varying material and thicknesses. I then exported each sheet to dxf for delivery. This job has raised a few questions that would help us reduce additional processing elsewhere.
1) When exported to dxf, the header information does not get exported as well. The result is that I have to manually add the material spec to each dxf created. Is there a way to make sure the header exports?
2) Layers - The cutting table expects layer 0 to represent the ID cuts and layer 1 to be all other cuts. In the export configuration file I do not see where I can set the layers for ID cuts. Is there such a setting that I maybe do not recognize?
Thanks for the help,
Steven
