Need the name of the font wich is empty inside.
WEISMAT
WEISMAT
Does anyone know what the name of that font is, which is empty inside. See my example for the letter "O". I created this example with ellipse and offset. ThxO-LIKE-OSLO.JPG
Xun.Zhang
Try font "Arial Narrow".
Hope it helps!
Xun
pball
Swis721 BLKOul BT is an outline only font on my Win10 system. I've used it to create a "watermark" on some drawings before.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
mcgyvr
All of the fonts that are available to Inventor are located in C:Windows/Fonts folder and you can just go there and look at the previews.
You can also download and install any "TrueType (.ttf extension)" font in that same location to allow it to be used by Inventor as well as any other Windows program that uses fonts in that standard location.
WEISMAT
To all 3 replies: Thank you very much for your help. Swiss721 is what I need.
