Why is 2x2 tube steel the smallest tube size?
Is anyone out there who would be kind enough to share custom frame generator profiles \ library?
Solved by kadscad. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
You know if you create your own custom read/write library - copy the structural profile family over to your read/write library, you can simple add rows/members and enter your own sizes...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Isn't there a download to expand frame generator material library? I need standard purchased material, not custom made. I don't want to waste time publishing standard pieces. Especially tubes, all that is there is pipe. And the sizes of tubes is very limited. Thanks for any help.
Gary
Maybe if someone is willing to share what they have, but there's no additional offical purchase or download that's out there.
Again you can create your own library, copy from an existing and modify as needed.
What are you exactly looking for?
Mark Lancaster
When you drop down the material list in frame generator to round tube, all it lists is pipe. I use both pipe and tubing. Also, the sizes are very limited.
