Need help with subtracting an assembly from a model
- Mute
- Permalink
- Report
Bear with me if this has been answered already, but I haven't seen a solution yet.
I need help subtracting a complicated assembly from a solid. I'm attaching example files to help describe what I'm trying to do. "EA1" is the assembly I'm trying to subtract and has been placed into "EA2"; EA1 references the solids "ES1" and "ES2" while EA2 only references ES2. In the assembly EA2, what ways could I subtract the assembly EA1 from the solid ES2?
For a simple example like this it's easy to just create a sketch based on projected edges then extrude-cut, but the actual assembly I'm working on has many more surfaces and bends to cut out so I can't easily and thoroughly do this.
Ideally, you could you the assembly itself to extrude-cut, but I haven't found a way to do that yet. I also read a couple threads where the sculpt tool was mentioned, but even after reading through the "To Trim, Extend, or Sculpt Surfaces" topic, I wasn't able to figure out how to use it: I was unable to select any surfaces on the solid nor on the assembly.
