Need help with modeling
Ivan_Sinicyn
Message 1 of 9
Ivan_Sinicyn
Guys,
help me with the construction of this design. Thought it would be easy, but I don't understand how to do the rounding on the corners🙉
INV 2025.3
Accepted solutions (4)
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
Look this:
(view in My Videos)
Kacper Suchomski
Message 3 of 9
" but I don't understand how to do the rounding on the corners"
I assume you mean the bent "wire" type item located on the origins of the base plates radius', correct?
Your best bet is to construct such as a 3D sketch, then locate the profile on the base plate at the intersection point of it and the 3D line you just created and sweep it along that 3D line (make sure the bend automatically put into the 3D sketch line is large enough for the profile to sweep around it and not overlap itself..
I doubt that is very clear, just don't have the time to demonstrate.
Message 4 of 9
CCarreiras
Hi!
You have to do an intersection between 2D curves:
Check the part attached
CCarreiras
Message 5 of 9
Frederick_Law
The corner round will not be banana.
Message 6 of 9
CCarreiras
Since you have several parts in the model, it would be better if you create an assembly...
Check the assembly file...
CCarreiras
Message 7 of 9
Ivan_Sinicyn
Guys, you're the best!
Thanks a lot, everybody!
INV 2025.3
Message 8 of 9
No, but it might be a pineapple.
Message 9 of 9
Frederick_Law
As long as not an angry pineapple .....
