Need Help With Extruding Through a Pattern
ampiricalsolutions
Message 1 of 15
ampiricalsolutions
I have this half ball with a bunch of divets created with patterns, trying to extrude through the pattern without success.
Any Ideas Thanks
Replies (14)
Message 2 of 15
CCarreiras
Hi!
Place the part here and we help you.
CCarreiras
Message 3 of 15
ampiricalsolutions
Here is the attached part.  Also I will need to patch the openeings for the bolt. Hopefully there is a better way to do this.  Using Inventor 2013
Anthony
Message 4 of 15
CCarreiras
Hi!
As long as this part is a multisolid part, you have to choose all the solids you need to be cut by the extrude.
Also you need to clean some remaining solids after the extrude.
Since i don't have 2013 version installed, i'm sending you a step file for you to check.
I guess i would do this part a little different... but... it works also like that.
CCarreiras
Message 5 of 15
IgorMir
Here is a bit simpler version of the part you are after. Please see the attached file, IV2010 format. Still, I see the same problem you have got. The last array doesn't remove some portion of the model.
The part is an iPart. Part1-01 exhibits the behavior you have described. Part1-02 shows some workaround to the problem.
I wonder if on latest version of IV this problem is resolved.
Cheers,
Igor.
Any Ideas Thanks
Web: www.meqc.com.au
Message 6 of 15
ampiricalsolutions
I appreciate all your help.  It turned out that this method was not good enough.  I need to try and create a golf ball in Inventor 2013.  Does anyone have any ideas?
Anthony
Message 7 of 15
mcgyvr
Anthony
Google is your friend..
"autodesk inventor golf ball"
http://forums.autodesk.com/t5/inventor-general-discussion/golf-ball-drawn-on-inventor-2010/td-p/2966...
Message 8 of 15
ampiricalsolutions
Thanks very much.
Anthony
Message 9 of 15
JDMather
I noticed that Sketch1 isn't constrained
and
this doesn't look right to me either?
Message 10 of 15
ampiricalsolutions
Ye those extrusions where made, then I used the patch command.  The main problem is creating the circular cutouts, then the circular half fill and making them pattern randomly (i.e golf ball), so this is an iteration of a bunch of unsuccessful attempts.  I attached a screen capture.  You will see those areas are designed for bolt tightening access.
Message 11 of 15
WHolzwarth
Boundary patch for the cutouts is no good. IMO this is better (2016 file)
Walter
Walter Holzwarth
Message 12 of 15
ampiricalsolutions
I like the style you used, but it needs to have a random pattern like a golfball.  This pattern is to even
Message 13 of 15
WHolzwarth
Smiley Wink Well, that's the existing pattern of your file.
Walter Holzwarth
Message 14 of 15
ampiricalsolutions
Ye I need to make it more like a golf ball, or use a different method.  This pattern doesnt work.  It really is there to show what I am trying to do with the sphere.
Message 15 of 15
WHolzwarth
Ok, make a new approach. It's not too difficult.
Walter Holzwarth
