Need help with assembly
Alhu19
Alhu19
Im trying to make a box with a movable top but cant figure out how to put it together
Pic of the Design
the threaded cylinder goes into the oval (number one) then a bolt screws into the threaded cylinder from the other side (number two), Afterward the top should be able to move up and down within the oval and back and fourth.
Will attach the parts in a zip file
Accepted solutions (3)
mcgyvr
Use a transitional constraint for that "pin in oval/slot"
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inve...
Alhu19
i did it and it worked, but the top does not rotate anymore, it only moves up and down
mcgyvr
Post the updated assembly or investigate the existing constraints to determine which one is now limiting that motion..
Apply constraints just like in real life and you should be able to duplicate the movement in real life..
I applied a transitional constraint on that pin and slot and then set the top and the box to be a "contact set" and turned on the contact solver and it behaved as expected..
WHolzwarth
Try a new Box.iam. All other files are unchanged.
Walter Holzwarth
JDMather
I made some changes to your model. (see Attached)
