Need help on making this object on Inventor.
Message 1 of 11
Hai;
     when i was doing autodesk inventor .i got some task . i couldnt do it. i am not good at using this software .Somebody can help me doing this task. i had uploaded pdf. there are three task  at task 1 - 22 th , task 2 -24 th, task 3 -25th. so please help me
Replies (10)
Message 2 of 11
TheCADWhisperer
These look like school assignments.
How much are you willing to pay to have someone complete your homework?
Has you instructor given the necessary instruction to complete the assignments?
Can you ask your instructor to join this discussion?
The users here will be happy to give you FREE help if you attach the *.ipt files of what you were able to complete so far.
@Anonymous
With your instructor's permission I can create a video on how to complete each one of these problems in 5-10 minutes.
Message 3 of 11
johnsonshiue
Hi Edwin,
You are a student taking a class learning 3D Modeling using Inventor, right? You are supposed to do your homework by yourself. You should not ask anybody do the homework for you. If you have trouble using the software, you need to talk to your teacher or teaching assistant. This forum is for solving technical issues, not helping do your homework.
If I were you, I would start with the tutorials shipped with Inventor. There are many high-quality tutorials on Autodesk Knowledge Network.
https://knowledge.autodesk.com/support/inventor-products/learn-explore?sort=score
Good luck!
Best wishes,
Software Test Engineer
Message 4 of 11
Hai
Can you provide video how to do this task then it will help me doing
this.pls
Message 5 of 11
TheCADWhisperer
@Anonymous wrote:
Hai
this.pls
Yes, I can do that as soon as your instructor Replies here that it is OK.
Message 6 of 11
Sir tried I can't do that task old help me.
Message 7 of 11
TheCADWhisperer
Can you attach the *.ipt of your attempt here?
Message 8 of 11
Task 1 ipt file
Message 9 of 11
TheCADWhisperer
@Anonymous
If you are attempting to Reply using a email - that will not work.
You need to log into the forum using a web browser to attach files here.
Message 10 of 11
Mark.Lancaster
@TheCADWhisperer
OP started another thread asking the same thing
https://forums.autodesk.com/t5/inventor-forum/help-in-some-doing-task-in-inventor/m-p/7748710#M68049...
Mark Lancaster
Message 11 of 11
S_May
Hi @Anonymous,
that looks anything like exams !!!
2018-02-03 16_03_30-2 task. Build 3D model and 2D drawing-1.pdf - Adobe Reader.png
they start to learn better, no one here in the forum does the work for them.
