Need help modeling a sheet metal fireplace hood
Canisalpha
Canisalpha
I have modeled what will be a fireplace hood . Flue pipes will attach to the holes and the part will be mounted atop a firebrick masonry structure. I need to create a flat pattern so that this part can be plasma cut on a 2mm thick steel sheet and welded up. I would like a tutorial or sequence of steps to help me place rips on the 4 sloping edges and then create a flat pattern.  I tried doing that but then I can't place bends that allow me to flatten the part. Any help would be appreciated.
Mark.Lancaster
@Canisalpha
When posting and sharing files make sure to always include Inventor version this file was last save with.  In you case its  Inventor 2020.2
Mark Lancaster
Canisalpha
Sure. Thanks for the tip.
JDMather
How many individual pieces do you want this to be?
1?
2?
3?
4?
5?
See Attached file.
Canisalpha
Thank You. The flat pattern you have created is what I was trying to do.
This was my first time modeling with sheet metal .
I hadn't realized that the corner tool could build up the sheet sections that way.
