Need Help Creating Carbon Nanotube
Message 1 of 30
Hello all,
I was wondering if anyone knew how I would go about making a carbon nanotube in Autodesk Inventor 2016. I'm not really familar with this type of software, I have used Google Sketchup before, but only briefly. If anyone could point me in the right direction, it would be greatly appreciated.  I attached some pictures of carbon nanotubes below.
https://upload.wikimedia.org/wikipedia/commons/5/53/Types_of_Carbon_Nanotubes.png
http://www.tasc-nt.or.jp/en/images/project/characteristic/img01.gif
Thank you!!!
Replies (29)
Message 21 of 30
ampster40
OP, in post #18, I am not sure but I think you might have mistaken "revolve" for "pattern". I think you want to create a circular pattern now - going by your screenshot in that post. Post #19, I think is still confusion between "revolve" and "pattern". Regarding Wisp's post (#20) - he appears to possibly be replying to my statement about how difficult modeling this stuff in a mechanical application such as Inventor can be. Due to the person I was replying to had made some statements about how "real" nanotubes are like, I tried to throw in a joke playing on the idea that using a mechanical application such as Inventor to design this stuff may not be the best thing. Sure, it will give you an approx model that may look sweet, but perhaps there is software out there that is better suited for modeling accurately nanotubes, molecules, etc. - if in fact you are looking for the real thing.
Message 22 of 30
I'm pretty close now.
What have I done wrong so that it looks like this and not smooth like MechMachineMan's post
Message 23 of 30
wispoxy
This is how you make Carbon Nanotubes Cat LOL
United States Patent No.:  7,556,789 B2
Date of Patent:  July 7, 2009
  Low temperature synthesis of carbon nanotubes
Abstract: Low temperature methods for synthesizing carbon nanotubes (CNTs) comprise decomposing a halogenated hydrocarbon in a fluid in the presence of a catalyst where the catalyst catalyzes the formation of a carbon phase comprising nanotubes…. In preferred embodiments, the catalyst comprises a metal encapsulated dendrimer molecule.
Example 1
Synthesis of 16:1, Iron Encapsulated Dendrimer
Generation “4” PPI dendrimer, 0.4156 g (commercial product of Sigma-Aldrich) is dissolved in 20 mL of water. A separate solution is made by adding FeCl3 .6H2 O, 0.5123 g to 20 mL of water. The two solutions are combined and mixed for one hour. The solution becomes dark brown to red. A third solution is made by dissolving sodium borohydride, 0.3303 g in 15 mL of water. The sodium borohydride solution is added dropwise to the combined dendrimer/iron chloride solution. The solution turns brown to black, a noticeable solid forms, and gas evolves. The combined solutions are mixed one hour after the addition of the sodium borohydride. The reaction mixture is centrifuged and the solvent is decanted. The reaction product is black. The material is dried for 48 hours.
Example 2
Iron PPI Dendrimer CNT Growth (Room Temperature)
In a round bottom flask, 0.062 g of the iron dendrimer catalyst of Example 1, 12 mL benzene, 2.7 mL tetrachloroethylene, and 0.99 g potassium are combined in an inert atmosphere. Potassium is trimmed with a razor blade prior to combining with the other ingredients in the round bottom flask in order to remove surface oxides. The mixture is stirred for one week in the round bottom flask in an inert atmosphere at room temperature. Afterward, the flask is removed from the inert atmospheric conditions. The potassium is removed and cleaned in a series of washes with t-butyl alcohol, methanol, and water. The reaction product is isolated by centrifugation and decantation of the liquid. Transmission electron microscopy shows the presence of CNTs in the reaction products, with observable diameters on the order of 15-20 nm. Raman spectroscopy shows graphitic peaks corresponding to MWNT growth.
Message 24 of 30
graemev
Late to the party, but...
When you look through the parameters used in the Tetrad part file, "a" is the bond length, "n" is the number of tetrads per ring, and "M" is the additional rows for skew arrangements.  Unfortunately, I don't know how to do helical patterns, so it's a bit of "manual" patterning in the assembly files.  I've modelled the Tetrad to make the assembly easier - mate the y-axes, mate atom node centers.
Modelled in IV2015 SP.2
Message 25 of 30
graemev
Too late for an edit...
"M" is additional rows.  If you have the zig-zag pattern shown in your attachment, M=0.  If you have the armchair pattern, M=n.
Message 26 of 30
Thanks you all for your insight, it is greatly appreciated. I'm not getting those errors anymore, and I would say I'm on the right track so far. Nanotubepic(new).jpg
Message 27 of 30
JDMather
Your feature tree shows errors - and there is no reason to use Adaptivity in this design.
Attach actual Inventor file(s) here rather than images.
Message 28 of 30
Can you please explain what you meant by "make a sketch around the hexagon axis?"
Message 29 of 30
TheCADWhisperer
Have you examined Sketch1?
Message 30 of 30
TheCADWhisperer
@Anonymous
Making any progress in this design?
