Need a Inventor challenge!
Message 1 of 23
I have a poor visual fantasy, so it`s probably a paradox that construction is a major at school. Nearly impossible to come up with any ideas on my own, so I need some help. Been using Inventor for the last year or so now and the lack of assignments from our teacher I am now reaching out.
I want challenges, by that I mean, a challenge that are intended for a guy in mid thirties who haven`t been doing much except from being a mechanic.
- Post a simple drawing that you want me to duplicate
- multiple parts to draw and assemble
- contain varius and progressive difficulties
I need practice practice practice, so help me out 🙂
PS! No off topic or discussions that aren`t relevant to the posts being put out.
Replies (22)
Message 2 of 23
Mark.Lancaster
@Anonymous
Not sure how well this will work for you..  But I pulled this out (attached image) from my technical (board) drafting book.  I'm not going to comment how long ago when I used this book to learn board drafting..  Smiley Very Happy
Vice.jpg  If this is too easy let me know..  I have other "designs" from this book..   Good luck..  And take it to the next step, maybe render it, IPN creation, and perhaps simulate the vice opening/closing.
Mark Lancaster
Message 3 of 23
blair
If you can't come up with ideas, then look around your room. Your desk lamp, desk, chair, table would be good simple starters. After that, what are your hobbies, mountain bike, long board...smart phone.
Pull out your calipers and start on a disc brake calipers and rotors.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 23
PaulMunford
That's a great image @Mark.Lancaster 🙂 Would you mind sharing which book it's from? I collect old technical drawing books - there's still a lot to learn from them!
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
Message 5 of 23
Mark.Lancaster
@PaulMunford
I will share as long as there's no comparison how old the book is to my age...  Smiley Very Happy  Meaning the book release was about 1 yr old when I got it new in college where I was taking CAD/CAM
https://www.amazon.com/Technical-Drawing-Computer-Graphics-7th/dp/002342690X
The title (on the book I have) has also the wording of "With Computer Graphics"..   Some days you just have to go back and look at the old drafting room images and large computer setups that are shown in this book.  Smiley Wink
Mark Lancaster
Message 6 of 23
TheCADWhisperer
@PaulMunford wrote:
 Would you mind sharing which book it's from? ....
Hey Paul, get the latest edition (15th) and I'll sign it for you.  Smiley Wink
Technical Drafting, Giesecke, et al.
@Anonymous
I recommend that you attach each part here as you complete it (and do 2D detail drawing of each).
I will comment on your techniques and offer suggestions.
Message 7 of 23
I know I can just input inches in a metric template, but I have no idea how to convert those measurements into a decimal number without using some form for table. Inches are hopelessly stupid, that`s my opinion.
Do you have it as a .jpg file so I can download it and turn it?
Message 8 of 23
TheCADWhisperer
Start from an inch template or Tools>Document Settings>Units and set to inches.
Then simply type in the numbers - the units are not an issue.
I attached an vertical image in previous post (not a scan).
I could find metric examples, but if units are a problem, I will bow out now.
Message 9 of 23
I have the inches template, but I prefer mm. But I just "convert" to the nearest whole number in my head and we are good to go. Thank you
Message 10 of 23
What is going on here, only two of the ears on one side will extrude, the two others wont. They are made and placed exactly a like......
Message 11 of 23
blair
If you are building a model that is symmetrical, build it centered about the center point: (0,0,0) which is the intersection of the Origin Planes. You only need to create either one of the "ears" and then "Mirror" it to the other corner and then mirror the two to the other side. In this case, mirror the two that you have created to the other side using the either one of the mid-plane Origin Planes or create a new Work Plane that is in the middle of your model.
A little planning ahead can save you work down the line. I always start all my models at the Origin Plane and were ever possible always try and extrude the primary shape in both directions to have one of the Origin Planes in the middle of my model, so that it can be used just for this purpose.
Delta Tau Chi ΔΤΧ
Message 12 of 23
asiteur
What I always find very inspirational is the autodesk Gallery:
https://gallery.autodesk.com/
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
Message 13 of 23
Thomas,
Never never ever design symmetrical stuff the way you see it !!!  Look at parts with the idea of maximizing laziness. In the given example I see a part that is symmetrical and if I imagine it without the top it is even 2 times symmetrical. If I would have to make it I would start with a quarter of the bottom part and construct it to the point where the top detailing changes. I would then mirror the solid along the short side so that I can add the top. Finally I would mirror the solid along the long side "et voila", part finished.
Alex
Message 14 of 23
Here you can download different 2d drawings (pdf).
http://www.inventorwizard.be/blueprints/index.html
Message 15 of 23
It`s not one symmetrical constraint on this one yet, but I don`t understand what you mean?
Message 16 of 23
YannickEnrico
Type 20 in, and the dimension will show up as 508. Even in a mm template.
Also, an inch is 25,4 mm, so you can just type 20x25,4.
Incase it's 6 1/4, do it like this: "(6+1/4)*25,4
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Message 17 of 23
Thomas,
Always look for symmetry in a part and organise your design to take advantage of it. In terms of effectiveness and "robust modelling" these are the steps from good to better :
  • Symmetric and equal constraints in sketches : saves you dimensions
  • mirror features : saves you sketches
  • mirror body : saves on all and always works
The part shown in attachment starts with one quarter of the part, mirrors once where the 2 sides are getting differenciated, mirrors finally along the symmetry axis.
Alex
Message 18 of 23
This is what I am going for, but my teacher don`t agree with me in mirroring.
Anyway I like that way of working, in time it will safe loads of time, but I have had a couple of bad experiences mirroring in sketch. So by this you mean 3D mirror?
Message 19 of 23
blair
I would hate to tell your teacher to get out in the real world and see how Inventor is to be used. We don't get paid to create all four lugs. Create one and mirror the other three.
1.) Plan your part before you even start your first sketch.
2.) Use the Origin Start Point: 0,0,0 (JD would be so proud of me)
3.) Always fully constrain your sketches. (JD would be so proud of me, again)
4.) When "Ever Possible" make use of extruding your primary sketch in both direction to take advantage of using one of the existing Origin Planes for Mirroring proposes.
5.) Keep your sketches as simple as possible, don't try and sketch the whole model with one sketch.
6.) If you can do the item later with a fillet or hole as a Feature do it then, don't do it in the sketch. It will be easier to fix as a Feature and easier to work with down stream in your model.
If you have the scree space, Ungroup and move up to the menu all the command. This will save you time hunting for commands in the drop-down menus.
You should forward this post on to him.
Delta Tau Chi ΔΤΧ
Message 20 of 23
Yes Thomas, 3D mirror is the way. Full body mirror whenever possible, feature mirror in other cases. A model should contain the absolute minimum of sketch entities. Mirroring in sketch clearly does not follow the rule of minimum sketch entities.
Feature mirroring also allows you to make "almost" mirrors IF you build your model with clear distinct features. For instance : if you have a part with an "ear" and a hole trough it you can choose to mirror the ear feature but not the hole feature, allowing a different hole on the other side.
Alex
