Nearest point rotating off
phaeronkor
phaeronkor
Hello!
Since don't know exactly which version of Inventor (currently using 23) there's auto possibility to rotate model with shift+middle mouse button that connects to nearest point, line Solidworks it does (previously rotating point was always at the center point of assembly).
Is it possible to turn this function off? I have not found such setting in option and I need to test something.
Thanks in advance!
johnsonshiue
Hi! Try changing the default Orbit type. Go to Tools -> App Options -> Display -> Default Orbit -> select the other option. I am not sure which one is active on your machine.
Many thanks!
Software Test Engineer
phaeronkor
That's exactly what I wanted! Thanks a lot!
