안녕하세요. 사용중인 인벤터는 2021버전 입니다.
(하위 버전은 2020,2015도 가능합니다.)
첨부된 부품 파일과 캡쳐 화면 참고 부탁드립니다.
캡쳐 화면과 같이 해당 부분으로 분할하여 각각의 솔리드로 구현을 하고 싶은데..
잘되지가 않네요.
좋은 방법이 없을까요?
첨부된 7100-1 RIG_TB_model(Block-FP) 파일은 원본이며, 내가 시도해본 파일은 7100-1 RIG_TB_model(Block-FP)_tryV1
입니다.
Good morning. The inventor in use is version 2021.
Please refer to the attached parts file and capture screen.
I want to implement each solid by dividing it into corresponding parts like the capture screen..
It's not going well.
Is there a good way?
The attached 7100-1 RIG_TB_model(Block-FP) file is the original, and the file I tried is 7100-1 RIG_TB_model(Block-FP)_tryV1.
In the file attached below (Inventor 2021), I was able to accomplish the split for one side, but not for the other. There are some very irregular spots in those interior surfaces, and I don't know how Inventor (or any other software) could handle those places smoothly. It would help, too, if you would post the assembly and two components that are derived into the part.
What is the end result supposed to be?
Sam B
Inventor Pro 2022 | Windows 10 Home 2004
LinkedIn
