Inventor Forum
My Style and Standard Editor Doesn't have everything
2 REPLIES 2
362 Views, 2 Replies
I am trying to change the precision from .000 to .0000 and I have seen that you are supposed to go to on "Style and standards editor" but when the window opens it only has "lighting" and "text" and none of the other options it should have. Does anyone know how to fix this problem? I am on Inventor 2018.
2 REPLIES 2
jhackney1972
If you are only seeing "lighting" and "text" you are in the modeling environment.  Precision of dimensions in 2D drawings is set by the Style and Standards editor.  In the 3D modeling environment the precision of the sketch dimensions is set under "Tools" "Document Settings" on the "Units" tab.  There you will find both linear and angular precision.
Please see my attached images.
John Hackney, Retired
johnsonshiue
Hi! John is right. If you want to change dimension display precision, you need to go to Tools -> Document Settings -> Units. If you are talking about dimension precision in Inventor drawing (idw and dwg), you will need to go to Styles and Standard Editor.
Many thanks!
Software Test Engineer
